Sarens是全球唯一一家客户能选择任何从小型吊机到世界最大吊装设备的公司。客户可以要求租用设备,即使一次仅几个小时。Sarens提供小型,可移动、且有巨大可能性的解决方案。
Sarens is the only company in the world that a client can approach for everything from a small crane up to the world’s largest lifting machine. Clients can even request to rent equipment for as little as a few hours at a time. Sarens provides small, easily-moveable solutions with enormous possibilities.
当在繁忙的布鲁塞尔市中心需要拆卸一台塔吊,并且吊装冷却器时,客户Van der Spek和THV Besix-Louis De Waele将这个项目交予Sarens来执行。由于是在一座城市的繁忙市中心,仅有有限的空间可以操作,Sarens决定采用利勃海尔LTM 1750吊机。LTM 1750的选择考虑到其能在同一工况情况下执行多种操作。吊机由11辆货车从Wolvertem基地陆运至现场。
When a tower crane had to be dismantled and coolers had to be lifted in the busy city center of Brussels, Van der Spek and THV Besix – Louis De Waele contacted Sarens to execute the operation. With limited space available due to a busy city center, Sarens decided to deploy its LTM 1750. LTM 1750 was selected as it could do both the jobs within the same boom/jib configuration. The crane was taken from the Wolvertem yard to the site location by road by eleven trailers.
利勃海尔LTM 1750在大约6小时内拆除了120米高、9吨重的塔吊。塔吊的底座部分被作为一个整段进行吊装。现场有限的操作空间是对吊机吊臂的一大挑战。我们的7人团队在5天内完成了全部操作。客户感谢团队的专业能力。
The LTM 1750 dismantled the tower crane, 120m high and weighing 9T, in around six hours. The base of the tower crane was lifted as one complete section. Limited space offered a challenge for outriggers and buildup of fly jib. Our crew of seven and the equipment completed the operation in five days. The client thanked the team for their professionalism. |
