查看: 481|回复: 0
利比亚拉斯拉努夫两台水蒸发器安装工程
发表于 2022-8-13 20:58 | 显示全部楼层 |阅读模式
全球物流领导者DB Schenker信任Sarens的设备和专业知识,并托付为其运输和安装利比亚拉斯拉努夫一家工厂的两台水蒸发器。
When global logistics leader DB Schenker needed to secure the transport and installation of two water evaporators for a plant in Ras Lanuf, Libya, they trusted Sarens’ equipment and expertise.
为确保操作的圆满完成,Sarens早在2021年9月完成运输路线的勘查。随后在2022年3月开展运输和安装操作。
To ensure a successful operation, Sarens first completed a route survey for transport in September of 2021. Then, during March of 2022, it conducted the transport and installation operation.
Sarens SPMT (自行式模块化运输车) 先将两台175吨的蒸发器从港口运至距离工厂1.5公里的地方,途中还需在下坡时转弯。然后蒸发器将被放置在PJ250顶升系统上进行垂直顶升约1.5米。Sarens随后将拖车横向放置在38米长的蒸发器下方,再将其安装至基桩上方。
Sarens SPMTs transported the two 175-tonne evaporators 1.5km from the port to the plant, driving downhill while turning. The evaporators were then set down onto the PJ250 jacking system for vertical transportation, and jacked up approximately 1.5 metres. Sarens positioned trailers transversally below the 38-metre long evaporators, installing them above foundation piles.
执行期间包括起重机和叉车司机在内共八名团队成员参与本次操作。
Eight crew members, including the crane driver and forklift operator, were involved in this operation.
GMT+8, 2024-5-20 12:11 , Processed in 1.281044 second(s), 21 queries .
