查看: 2805|回复: 12
GMK6300L&GMK6400 podcast
发表于 2010-4-28 00:13 | 显示全部楼层 |阅读模式
©MCG bauma 2010 GMK6300L&GMK6400 podcast
发表于 2010-4-28 09:08 | 显示全部楼层
听不 懂
发表于 2010-4-28 16:59 | 显示全部楼层
Manitowoc is to present the ‘world’s most powerful six-axle all terrain crane’ at Bauma 2010, the Grove GMK6400.
The 400t capacity all terrain has a maximum main boom length of 60m and a maximum tip height of 136m.
The Grove GMK6400 all terrain crane can be equipped with a mega wing lift capacity-enhancing attachment, which Manitowoc said allows the crane to offer ‘significant lift capabilities’, which are up to 35% stronger than similar cranes.
The mega wing lift attachment provides extra support to the boom. It is equipped with a self-rigging system that mounts on the chassis and connects to the boom. When the boom is in working position, the mega wing lift attachment extends laterally to stiffen the boom.
Grove’s GMK6400 all terrain crane operates using a single engine for both travelling and crane operations, which reduces weight and improves fuel economy. This is a Mercedes OM 502 Tier 4i eight-cylinder engine that produces 405kW at 1,800rpm, powering a ZF AS Tronic 12 transmission.
“Our engineers discovered that smaller engines, which are typically used to power lift operations in the superstructure, use more fuel when they operate at the higher RPM needed for actions like slewing, telescoping and luffing,” said Neil Hollingshead, Manitowoc’s global product director for all terrain and rough terrain cranes.
“Using a larger, single engine operating at lower RPM, as featured on the GMK6400, is actually more fuel efficient.”
This is coupled with a MegaDrive hybrid drive system for travelling at lower speeds. This gives the crane more efficient fuel consumption, a lower centre of gravity and longer lasting parts, Manitowoc said. MegaDrive powers the crane when it is accelerating to speeds of approximately 20km/h, and then the conventional drive takes over. MegaDrive activates when decelerating below a similar speed.
Manitowoc added MegaDrive gives better traction on poor surfaces for easier on-site manoeuvre, especially when combined with Grove’s Megatrak independent suspension system.
“We’ve concentrated on all aspects of owning and operating cranes, particularly the issues our customers care about, including fuel efficiency, versatility, reach and productivity,” said Hollingshead.
“Above all, we focussed on strength. Customer feedback told us not to compromise the load chart for a few extra metres of boom. We followed that advice, and when customers see the charts, there are clear advantages over other cranes in this class. This crane is a new design and we believe it sets new standards in heavy lifting for six-axle all terrain cranes.”
发表于 2010-4-28 17:00 | 显示全部楼层
这个是网上找的  自己听了好多次 听出来95%, 有一些技术上的专用术语听不出来
发表于 2010-4-28 17:03 | 显示全部楼层
这个也不完全是对话的内容 但是和对话的内容差不多
 楼主| 发表于 2010-4-28 17:30 | 显示全部楼层
是,差不多就是这个意思
发表于 2010-6-16 21:44 | 显示全部楼层
4楼英语专业毕业吗???
发表于 2010-6-20 23:14 | 显示全部楼层
Manitowoc is to present the ‘world’s most powerful six-axle all terrain crane’ at Bauma 2010, the ...
2846666 发表于 2010-4-28 16:59 [url=http://www.cranebbs.com/bbs/images/common/back.gif]http://www.cranebbs.com/bbs/images/common/back.gif[/url]
    听出来就翻译给兄弟们看看啊……:lol
发表于 2010-6-21 08:32 | 显示全部楼层
回复 7# 鑫达吊装
    专业倒是实在不敢当 略懂一二 前辈见笑
发表于 2010-8-18 23:56 | 显示全部楼层
英语不太懂,呵呵。
发表于 2011-1-2 17:22 | 显示全部楼层
不太懂
发表于 2012-2-23 11:11 | 显示全部楼层
发表于 2012-2-23 22:13 | 显示全部楼层
GMT+8, 2026-9-10 02:54 , Processed in 1.248826 second(s), 19 queries .
