查看: 1622|回复: 0
比利时Sarens在土耳其首座垃圾电站吊装工程
发表于 2020-4-1 17:09 | 显示全部楼层 |阅读模式
Sarens是全球大件吊装租赁的领导者,所以当HZI-Makyol公司需要四台塔式吊机来帮助建造在伊斯坦布尔的垃圾发电厂时,Sarens很荣幸能为客户提供世界级的设备。
Sarens is a global leader in heavy lifting equipment rental, so when HZI-Makyol needed four heavy luffing tower cranes to help build their energy-from-waste (EfW) power plant in Istanbul, Sarens was pleased to provide them with world-class equipment.
Sarens为此次项目提供的设备有:
Sarens provided the following tower cranes for the project:
HLTC 1900: 50m tower, 60m jib
HLTC 2400: 45m tower, 60m jib
Wolff WK60140B, 40m tower, 60m jib
吊机将在现场为项目服务6至8个月。为垃圾电厂部件进行吊装操作,电厂位于一座多风的山上。幸运的是,Sarens特有的塔吊能完全适应这类作业,能抵抗更强的风力限制,可以在17米每秒的风速下运作。
The cranes will remain on site for 6-8 months of the project. There, they will lift components of the EfW power plant, which is being built atop a notoriously windy hill. Fortunately, Sarens’ luffing tower cranes are uniquely suited to the job: with higher wind limitations than telescopic or crawler cranes, they can operate at wind speeds of up to 17 m/s!
这款塔吊还有其他几项优势,包括:
The tower cranes come with several other important advantages, including:
可以安装于建筑物中央或者工作现场。
The ability to be installed in the middle of a building or work site.
装配所需空间极小。
Minimal space required for assembly.
操作过程中对作业空间的占用较小。
Minimal occupation of work site during operations.
与伸缩式或履带式吊机相比,性价比更高。
Better cost efficiency versus telescopic or crawler cranes.
无压载负担
No hassle with SL ballast.
项目经理Jonathan Verheye表示:“这个项目向大家展示了Sarens大型塔式起重机如何为全球客户服务”,另外“我们的HLTC吊机能为建造行业提供高经济性及高可靠性的解决方案。”
“This project is a statement of how Sarens’ heavy lift tower cranes can help our clients worldwide with heavy construction,” says project manager Jonathan Verheye. “Our HLTC cranes are a cost-efficient and highly reliable solution for the heavy lift construction industry.”
GMT+8, 2026-11-5 06:06 , Processed in 0.041754 second(s), 29 queries .
