查看: 32988|回复: 165
打捞库尔斯克号Kursk
发表于 2007-8-19 20:45 | 显示全部楼层 |阅读模式
MAMMOET大概是世界上最牛的吊装公司了
 楼主| 发表于 2007-8-19 20:46 | 显示全部楼层
库尔斯克残骸
发表于 2007-8-19 21:14 | 显示全部楼层
我记得是26个液压提升机构把艇提起来的,每个提升机构的钢索破断拉力是900吨。
发表于 2007-8-19 21:44 | 显示全部楼层
打捞的那艘船是驳船,名字叫巨人4号(Giant 4),不是起重船。
 楼主| 发表于 2007-8-19 22:01 | 显示全部楼层
英文介绍
K-141 Kursk was a Russian nuclear cruise missile submarine which was lost with all hands when it sank in the Barents Sea on August 12, 2000. It was named after the Russian city Kursk, around which the largest tank battle in military history, the Battle of Kursk, took place in 1943.
The Kursk sailed out to sea to perform an exercise of firing dummy torpedoes at Pyotr Velikiy, a Kirov class battlecruiser. On August 12, 2000 at 11:28 local time (07:28 UTC), the missiles were fired, but an explosion occurred soon after on Kursk. The only credible report to-date is that this was due to the failure and explosion of one of Kursk’s new/developmental torpedoes. The chemical explosion blasted with the force of 100-250 kg of TNT and registered 2.2 on the Richter scale [1]. The submarine sank to a depth of 108 metres, approximately 135km (85 miles) off Severomorsk, at 69°40′N, 37°35′E. A second explosion 135 seconds after the initial event measured between 3.5 and 4.4 on the Richter scale, equivalent to 3-7 tons of TNT [2]. Either this explosion or the earlier one propelled large pieces of debris far back through the submarine.
Kursk was eventually raised from her grave by a Dutch team using the barge Giant 4, and 115 of the 118 dead were recovered and laid to rest in Russia. Russian officials have strenuously denied claims that the sub was carrying nuclear warheads. When the boat was raised by a salvage operation in 2001 there were considerable fears moving the wreck could trigger explosions.
 楼主| 发表于 2007-8-19 22:02 | 显示全部楼层
介绍2
The mission began in earnest on the morning of August 12, 2000. As part of the exercise, Kursk was to fire two dummy torpedoes at a Kirov-class battlecruiser. At 11:28 local time (07:28 UTC), high test peroxide (HTP), a form of highly concentrated hydrogen peroxide used as propellant for the torpedo, seeped through rust in the torpedo casing. The HTP reacted with copper and brass in the tube from which the torpedo was fired, causing a chain reaction, leading to a chemical explosion.
The watertight door separating the torpedo room from the rest of the sub was left open prior to firing. This was apparently common practice, on account of excess compressed air being released into the torpedo room when a weapon was fired. The open door allowed the blast to rip back through the first two of nine compartments on the huge sub, probably killing the seven men in the first compartment, and at least injuring or disorienting the thirty-six men in the second compartment.
After the first explosion, due to the fact the air conditioning duct was quite light, the blast wave traveled to more compartments, including the command post filling them with smoke and flames. After the explosion, the captain was believed to be trying to order an ‘emergency blow’ which causes the sub to rapidly rise to the surface, but he was quickly overcome with smoke. An emergency buoy, designed to release from a submarine automatically when emergency conditions such as rapidly changing pressure or fire are detected and intended to help rescuers locate the stricken vessel, also failed to deploy. The previous summer, in a Mediterranean mission, fears of the buoy accidentally deploying, and thereby revealing the sub’s position to the US fleet, had led to the buoy being disabled.
Two minutes and fifteen seconds after the initial eruption, a much larger explosion ripped through the sub. Seismic data from stations across Northern Europe show that the explosion occurred at the same depth as the sea bed, suggesting that the sub had collided with the sea floor which, combined with rising temperatures due to the initial explosion, had caused further torpedoes to explode. The second explosion was equivalent to 3–7 tons of TNT, or about a half-dozen torpedo warheads and measured 3.5 on the Richter scale. After the second explosion, the nuclear reactors were shut down to prevent a nuclear disaster, although the blast was almost enough to destroy the reactors.
The second explosion ripped a two-metre-square hole in the hull of the craft, which was designed to withstand depths of 1000 meters. The explosion also ripped open the third and fourth compartments. Water poured into these compartments at 90,000 litres per second – killing all those in the compartments, including five officers from 7th SSGN Division Headquarters. The fifth compartment contained the ship’s nuclear reactors, encased in a further five inches of steel. The bulkheads of the fifth compartment withstood the explosion, causing the nuclear control rods to stay in place and prevent nuclear disaster. Western experts have expressed strong admiration for the Soviet/Russian engineering skill to create a submarine that withstood so much.
Twenty-three men working in the sixth through to ninth compartments survived the two blasts. They gathered in the ninth compartment, which contained the secondary escape tunnel (the primary tunnel was in the destroyed second compartment). Captain-lieutenant Dmitri Kolesnikov (one of three officers of that rank surviving) appears to have taken charge, writing down the names of those who were in the ninth compartment. The pressure in the compartment at the time of the explosion was the same as that of the surface. Thus it would be possible from a physiological point of view to use the escape hatch to leave the submarine one man at a time, swimming up through 100 metres of Arctic water in a survival suit, to await help floating at the surface. It is not known if the escape hatch was workable from the inside – opinions still differ about how badly the hatch was damaged. However it is likely that the men rejected using the perilous escape hatch even if it were operable. They may have preferred instead to take their chances waiting for a rescue vessel to clamp itself onto the escape hatch.
It is not known with certainty how long the remaining men survived in the compartment. As the nuclear reactors had automatically shut down, emergency power soon ran out, plunging the crew into complete blackness and falling temperatures. Kolesnikov wrote two further messages, much less tidily than before. In the last, he wrote:
“It’s dark here to write, but I’ll try by feel. It seems like there are no chances, 10-20%. Let’s hope that at least someone will read this. Here’s the list of personnel from the other sections, who are now in the ninth and will attempt to get out. Regards to everybody, no need to be desperate. Kolesnikov.”
发表于 2007-8-20 08:19 | 显示全部楼层
原帖由 超级海盗 于 2007-8-19 21:44 发表
没有人说是起重船啊?:L :L
发表于 2007-8-20 18:59 | 显示全部楼层
回复 #7 安安YOYO 的帖子
应该是玛姆特跟斯密特一起打捞库艇,斯密特是著名的海事工程公司:)
发表于 2007-8-20 23:52 | 显示全部楼层
起重巨人——MAMMOET公司
荷兰MAMMOET公司成立于1971年,在世界23个国家设有分公司,拥有员工1400人。该公司专门从事石化工业、海岸建设、重力机械、矿产开发、民用建筑等方面的运输和起吊业务。该公司在重力起吊和运输领域拥有良好声誉,特别是在海上起重、吊车起重和垂直起重方面有卓越的专业经验。MAMMOET公司拥有世界上最大的地面起重机,能起吊陆地上最重的东西。
发表于 2007-8-23 12:17 | 显示全部楼层
MAMMOET公司据说已经放弃大陆的分公司了,解散了。
发表于 2007-8-23 19:37 | 显示全部楼层
是因为中国的生意不好做吧
发表于 2007-8-23 20:23 | 显示全部楼层
中国的市场那么大,没可能吧????
发表于 2007-8-24 13:41 | 显示全部楼层
听说他们的司机都发遣散费了的说
 楼主| 发表于 2007-8-24 23:53 | 显示全部楼层
打捞的第1阶段
在阿姆斯特丹建造巨人4号打捞船,船长140米,宽36米。船上带有26个起重系统,每个最大起重量900吨。
 楼主| 发表于 2007-8-25 00:16 | 显示全部楼层
打捞的第2阶段
潜水员将潜艇头部切割下来放在海床上,用含有研磨剂的高压水在潜艇身上打洞,俄海军带着潜艇设计师鲁宾对打洞的精确位置进行确定。这些工作都是在0~6摄氏度水温下进行的。
发表于 2007-8-27 14:06 | 显示全部楼层
楼上兄弟辛苦了,截图很费时间的
 楼主| 发表于 2007-8-28 00:09 | 显示全部楼层
打捞的第3阶段
将26根起重钢缆(每根钢缆由54根细一些的钢绳组成)从打捞船上放下,每根钢缆头部都带有一个巨大的夹持器,将26个夹持器分别放入潜艇舱壁被切割开的26个孔中,夹持器张开,将起重钢缆固定在潜艇舱壁上。
 楼主| 发表于 2007-8-28 00:27 | 显示全部楼层
打捞的第4阶段
26套起重系统开始工作,将潜艇缓缓提升到打捞船底部。在海浪中作业容易导致26根钢缆受力不均匀,MAMMOET为此研制了海浪补偿系统,通过电脑计算控制26个起重系统,这26个起重系统每个通过2个可伸缩液压缸调整钢缆受力,在海浪补偿系统的电脑自动控制下,保证每根钢缆受力均匀稳定。
 楼主| 发表于 2007-8-28 00:46 | 显示全部楼层
打捞的第5阶段
巨人4号底部带着潜艇,由拖轮拖航到摩尔曼斯克,到达后,由已经建好的两艘浮船从巨人4号两侧将其托起,然后由12艘拖轮将其拖到干船坞中。至此,全部打捞工作完成。
发表于 2007-10-13 23:24 | 显示全部楼层
继续温习下.
发表于 2007-10-14 01:23 | 显示全部楼层
:victory: :victory: :victory:
发表于 2008-2-21 19:25 | 显示全部楼层
发表于 2008-2-21 19:36 | 显示全部楼层
发表于 2008-7-12 22:22 | 显示全部楼层
厉害!
发表于 2008-8-8 14:46 | 显示全部楼层
辛苦了
发表于 2008-8-11 21:12 | 显示全部楼层
太强了,高人真多
发表于 2008-8-27 21:48 | 显示全部楼层
好像在TV上看过,顶下是最起码的:lol :lol :lol
发表于 2008-8-29 13:55 | 显示全部楼层
起重机爱好者,刚刚入门,希望跟各位前辈多学习
发表于 2008-11-7 12:30 | 显示全部楼层
太强了!
发表于 2008-11-18 16:47 | 显示全部楼层
厉害厉害
发表于 2008-12-7 23:16 | 显示全部楼层
:victory: :victory:
发表于 2008-12-18 11:07 | 显示全部楼层
厉害   赞
发表于 2008-12-30 12:11 | 显示全部楼层
新人在论坛看的东西确实很开眼,坛子里的坛友水平都很高!确实得好好学习!:handshake
发表于 2008-12-30 13:27 | 显示全部楼层
我有一盘它打捞时的DVD,非常棒
发表于 2008-12-30 14:04 | 显示全部楼层
牛X,顶,辛苦了
发表于 2008-12-30 20:13 | 显示全部楼层
我有全套的,系列的:lol :lol :lol 有人要租么?
发表于 2009-1-22 23:50 | 显示全部楼层
原帖由 LR1750 于 2007-8-19 22:01 发表 http://www.cranebbs.com/bbs/images/common/back.gif
K-141 Kursk was a Russian nuclear cruise missile submarine which was lost with all hands when it sank in the Barents Sea on August 12, 2000. It was named after the Russian city Kursk, around which the ...
K - 141是俄罗斯库尔斯克核巡航导弹潜艇是失去了所有的手时,在巴伦支海沉没于2000年8月12号。它被命名后,俄罗斯库尔斯克市,围绕着最大的坦克战中的军事历史,库尔斯克战役中,发生在1943年。 ( G2a !的O / 〜 ( _ # K7K
<BR>
<BR>的库尔斯克号出海执行行使鱼雷发射假人在彼得基Velikiy ,一个基洛夫级battlecruiser 。 8月12日, 2000年在本地时间11时28 ( 07:28 UTC )表示,该枚导弹,但发生爆炸后不久,就库尔斯克。唯一可信的报告,最新的是,这是由于未能与爆炸之一库尔斯克新/发展鱼雷。化学品爆炸,爆炸的力量100-250公斤TNT炸药和2.2级[ 1 ] 。潜艇沉没深度为108米,大约135公里( 85英里)从Severomorsk ,在69 ° 40'N , 37 ° 35'E 。第二次爆炸一百三十五秒事件后的初步测定3.5和4.4级,相当于3-7吨TNT [ 2 ] 。这一爆炸或任何早先推进大块碎片早通过submarine.9 a5V + q ; ? /年* &#246; : &#12316;阿
<BR>
<BR>库尔斯克,最终她提出严重的荷兰队利用驳船巨人4 , 115的118个死者中有回收和安葬在俄罗斯。俄罗斯官员极力否认索赔小组携带核弹头。当该船所提出打捞作业在2001年有相当大的恐惧移动的残骸可能会引发爆炸。
原帖由 LR1750 于 2007-8-19 22:02 发表 http://www.cranebbs.com/bbs/images/common/back.gif
The mission began in earnest on the morning of August 12, 2000. As part of the exercise, Kursk was to fire two dummy torpedoes at a Kirov-class battlecruiser. At 11:28 local time (07:28 UTC), high tes ...
特派团认真开始了上午的会议上2000年8月12号。作为行使,库尔斯克是火灾两个假人鱼雷在基洛夫级battlecruiser 。在本地时间11时28分( 07:28 UTC )表示,高测试过氧化氢(高温高压) ,一种形式的高度集中的过氧化氢作为推进剂的鱼雷,渗入通过锈病鱼雷套管。在高温高压反应,铜和黄铜在管从鱼雷发射,造成连锁反应,导致化学品爆炸。 # X “的&#12316; (丁! &#246; %的+ c6A6 ( * &#376;&#160;
<BR>
<BR>分离的水密门鱼雷室的其他小组留下开放之前发射。这显然是常见的做法,考虑到过剩的压缩空气释放到房间鱼雷武器时被解雇。开放使高炉淘汰后的头两年,共有九个舱上巨大的分,可能杀害七名男子第一舱室,至少炸伤或迷失方向的36人中的第二个舱室。 )小时:的S /吨: `我
<BR>
<BR>第一次爆炸后,由于空调管道是相当轻的冲击波前往更多的舱室,包括指挥所注入烟雾和火焰。爆炸发生后,船长被认为是试图以一种紧急的打击,从而导致小组迅速上升到表面,但他很快就克服烟雾。紧急浮标,旨在释放从潜艇紧急情况时自动等迅速变化的压力或火灾被发现,并打算以帮助救援人员找到受灾船只,也没有部署。以前的夏天,在地中海的任务,担心意外的浮标部署,从而揭示小组的立场的美国舰队,已导致浮标被禁用。&#160;
<BR> $ ( 6V9Y , U9J “ p5T % × (小( é&#160;
<BR>两分钟和15秒后,最初的爆发,一个更大的爆炸小组。地震资料站整个北欧表明,爆炸发生在同一深度的海床,表明了小组相撞海底,加上气温上升,由于最初的爆炸,造成了进一步的鱼雷爆炸。第二次爆炸相当于3-7吨TNT ,或大约半打鱼雷弹头和测量3.5级。在第二次爆炸,核反应堆被关闭,以防止核灾难,虽然爆炸几乎足以摧毁反应堆。&#160;
<BR> : 1 % \三号乙* &#376; + G7x6Z&#160;
<BR>第二次爆炸,两米的方孔中的船体的工艺,其目的是抵挡深度1000米。爆炸还剖开的第三和第四次舱室。水涌入这些舱室在九点○万升每秒-杀死所有的舱室,包括5名来自第七SSGN司总部。第五舱载船舶的核反应堆,装在一个进一步五英寸钢。舱壁第五舱经受爆炸,导致核控制棒留在地方和防止核灾难。西方专家们表示了强烈的钦佩苏联/俄罗斯工程技术创造一个潜艇顶住这么多。&#160;
<BR>
<BR> 23名男性工作在第六至第九舱幸存的两起爆炸事件。他们聚集在第九舱,其中载有中学逃生隧道(主要隧道是在被摧毁的第二个隔间) 。上尉,中尉德米特里科列斯尼科夫(其中3名军官的军衔尚存)似乎已经采取收费,写下来的人的姓名是谁在第九舱。中的压力室的时候,爆炸是相同的表面。因此,将有可能从生理的角度来看,使用逃生舱口离开潜艇一名男子在一个时间,游泳,通过100米的北极水在救生服,等待帮助浮在表面。目前尚不清楚,如果是可行的逃生舱口从内部-意见仍然存在分歧如何严重舱口被损坏。不过可能是男子拒绝使用危险的逃生舱口即使有可操作性。他们可能更倾向于采取相反的机会等待救援船只钳本身到逃生舱口。最大的起重机论坛-吊车论坛-吊装论坛最大的起重机site1h7t $ X % d个+乙/ \ ) &#382;&#160;
<BR>
<BR>目前还不知道如何把握剩下的男子长期存活的舱室。作为核反应堆已自动关闭,紧急供电很快失控,致使船员到完整的黑暗和下降的温度。科列斯尼科夫写道两个进一步的信息,更整齐了。在过去,他写道:&#160;
<BR>
<BR> “这是黑暗的写在这里,但我会尽力的感觉。好像没有机会, 10-20 % 。让我们希望,至少有人会阅读。这里的工作人员名单中的其他章节,谁现在是第九届和将试图摆脱。对于每个人,没有必要绝望。科列斯尼科夫。 “
发表于 2009-1-22 23:51 | 显示全部楼层
google translator的翻译:lol
发表于 2009-1-30 14:36 | 显示全部楼层
这就叫语无伦次~~~
GMT+8, 2026-9-10 10:00 , Processed in 1.202668 second(s), 23 queries .
